How to join threaded brass fittings
View the thread, titled "How to join threaded brass fittings" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi.
I'm fitting a new shower valve (Grohe Rapido T universal) it has 1/2" inlet and outlet ports to connect to so have got some 15mm x 1/2" male unions (I think that's the correct term) both straight and elbows. I've tried to find out how to fit the brass fittings and there's lots of conflicting info out there (perhaps some of it is US so based on NPT - but I'm pretty sure these are parallel threads). The questions I have are:
1. Should I use anything on the fittings (PTFE, pipe dope)
2. The elbows seem to go in hand tight and then stop after about a quarter turn with a spanner so how do I get them to point the direction I need them to
3. Probably hard to answer this but how tight should they be
yes they need somthing
pfte
loctite 55
loctite 577
for me either 577 or 55 would be the option if you use pfte put enough on and with all methods leak test before you fill the wall in / tile
Thanks Shaun. With using loctite does it mean the threads can be just hand tightened in which case I can point the elbows anywhere I like even if they are loose before applying the loctite
577 can also if you put the right number of turns on 55 can (it won't be hand tight you will need a spanner or grips etc)
Some of the NPT (fuel) threads, also know as 'dryseal' can be use without any sealant but TBH I've never had the nerve to try it any usually use PTFE tape.
Tried to find somewhere that had 577 which looked like it was probably the easier and possibly better option but couldn't find it locally so got some 55. Seemed easy enough although I think I put one on the wrong way around as it shredded it a bit before I got used to which way around to do it! I'll see what happens when I leak test it but it'll probably take me a few days to get the rest of the pipe work in place ready for that. No idea if any of the connections are tight enough but given all the warnings about don't over tighten I've tried to go on the side of not killing it and if it needs more when I test it will adjust then
Thanks for the info Marvoni but that sounds a bit beyond me. I'm just working on a shower valve and I don't know if you can get NPT (tapered which would be BSPT in the UK) threads for shower valves. I'm pretty sure mine are BSPP (parallel). NPS would be the equivalent in the US system according to a web search but although they are the nearest equivalent in the two systems it says they are not compatible
Here's some data on pipe thread if it's any interest.
Reply to the thread, titled "How to join threaded brass fittings" which is posted in UK Plumbers Forums on Plumbers Forums.
Chris 11,
fixitflav,
