How to remove 'top' of tap?
View the thread, titled "How to remove 'top' of tap?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I need to fix a dripping tap - I thought by removing the screw at the top of the blue section the top of the tap would lift off... no such luck...
it is 'loose' but is stuck and won't lift up.
How do I get it off to then replace the washer?
Thanks in advance.
That blue plastic bit should lift out, then you should be able to apply a lubricant or pour boiling water over it. Once you have the top off, you need to undo the tap insert.
Reply to the thread, titled "How to remove 'top' of tap?" which is posted in UK Plumbers Forums on Plumbers Forums.
Neil23,
Neil23,
