How to replace thermostat cartridge
View the thread, titled "How to replace thermostat cartridge" which is posted in Bathroom Advice on UK Plumbers Forums.
Hi Folks, Need your advice on how to access a thermostat cartridge to fix/replace. Please see pics below. I have manged to to get the main shower control cartridge out as it is leaking badly. But now need to sort the thermostat/mixer out now as very stiff and difficult to turn to cold. The problem is I can't work out how to get the chrome surround off, which I am assuming I need to do to access it. It is the bottom one in third picture. Could anyone please advise?
Have got chrome collar off, but now can't work out what to do next.
Bigger spanner.
If using adjustable spanner, ensure a perfect fit to prevent rounding it off. Get a steel tube to put over spanner handle for more leverage.
I’ve never come across one that I’ve needed to heat or won’t eventually come out.
Show it who’s boss!
Sometimes the flat sections on the brass will round off even with a good spanner. In that case, a quality Stilson wrench may be usefully employed.
If you haven’t got a set of the Rothenberger R type wrenches, you’re missing out.
Once they’ve bit, they rarely slip. I’ve got them in 6”, 8” & 12”. The 6” ones are great because they close small enough for turning old seized stopcock/gate valve spindles.
Toolbox already overfilled. Actually considering removing the Footprint wrench: I put it in when I started out as it's a classic tool, but in reality I have yet to find a use for it that something else won't do better.
My UK-made Record leader wrench (found on a roundabout!) is amazing though.
Tbh, I might remove my footies, can’t remember the last time I used them....
I bought the wera joker self setting spanner, I thought if it could do both 15mm and 22mm compression nuts, it would be handy in tight spaces.
I emailed them to confirm the jaw could fit 22mm, they confirmed.
Bought it, some 22mm nuts don’t fit and its a pain in the bum to use.
Very disappointed, love all my other wera tools. Complete waste of money. Used it once and never again.
Perhaps they thought the nut dimension was 22mm?
Reply to the thread, titled "How to replace thermostat cartridge" which is posted in Bathroom Advice on Plumbers Forums.
zack6600,
Deleted member 120897,
