How to reset boiler after power cut Glow worm 330 or 350
View the thread, titled "How to reset boiler after power cut Glow worm 330 or 350" which is posted in Boiler Advice Forum on UK Plumbers Forums.
rpm
Subscribed
Hi guys n gals, just had call from sister asking if I can come and reset her boiler which isn`t working after a 15hr power cut. From memory I think it`s a Glow worm 330 or 350, anybody know where the button would be.
Thanks in advance
From memory I think its one of those reset buttons that you need a pen or matchstick or something small to push in a little white reset button on the user controls on the front of the boiler.
Failing that, hat, turn it off then on again 🙂
Let us know which boiler exactly and we will be able to give the correct advice CHKing
Thanks in advance
Pretty sure the 330 is a re-branded BG boiler, just the old HXi I think. As villa tom said, it is a small reset button which you need something very small to be able to press it.
Thanks for the answers so far guys but its not working.
A friend is on site so trying to do this in a 3 way manner. It is a BG 330 and I`m told the resert switch is an on / off switch (no button found) and he has tried turning it off / on.
Im a saniflo guy and the my friend on site is a motorcycle mechanic, are you able to say more?
There is a little reset button on those boilers, you can only get to it with the tip of a pen or something very small so he could be missing it.
Many thanks to all that replied.
I`ve just been and had a look for myself and what I found was it is a BG330 with reset switch not a button and the instructions on how to reset are clearly seen on the instructions sticker when you pull down the flap to expose the switch and a stat.
When you turn the reset switch on the fan runs for a split second the stops and the little green light goes out but there is no error code the display stays showing 44.
Also I can`t understand how there is still hot-ish water at the kitchen sink when the power cut was +24 hrs ago and the power was restored around miday today and all rads are stone cold, and I have checked the program controller in the airing cupboard which appears to be working.
As before, thanks in advanced.
Is there anybody in the RG41 area willing to take a look if she can`t get it sorted?
Please PM a contact name & number.
Thanks.
Reply to the thread, titled "How to reset boiler after power cut Glow worm 330 or 350" which is posted in Boiler Advice Forum on Plumbers Forums.
rpm,
rpm,
