Jun 20, 2023
Scotland
DIY or Homeowner
Hi everyone đź‘‹
I am getting a secondary rad put in under our windows. The first one is a double panel with fins. This is to try and boost a little as room gets slightly chilly in winter. I've looked at the calcs online, and I think a single panel with fins, type 11, should do the trick. I thought the type 11 is better because it'll not stick out as much.
Anyway. My question is then how wide should I go for aesthetics. The 300 X 1400 has been suggested, as it'll align neatly with the middle window. But I notice there is a 300 X 2000 option in this range.
What do you think visually looks best? I don't want it to dominate, but then I also don't want it looking pokey
Thank you ShaunC - I think I might go for the type 21 1400 wide. Good to know that about the type 11. A family member straight away recommended I get a type 10, no fins... He said it'd be cheaper to run and flush to the wall. The plumber said 21 or 22, although I think 22 probably is too much. The room is 3.2 by 4.6 roughly speaking, so not huge but equally not tiny
One plumber suggested getting a Stelrad 450 X 1600 K2 and then replacing the existing 600 X 1200 P+ with a smaller Stelrad 600 X 600 as boost.
The other plumber suggested adding the 300 x 1400 (from VictorianPlumbing), type 11 although at my direction. They would install other products as needed.
