birchjc
Advice Please!
Hot water is coming up the pipe that would normally provide cold water to the hot water tank, it fills the HW Feeder tank and causes it to overflow. The vent is dry and the ballcock is working. The Feeder tank is warming up and I an feel the pipe at the bottom is hot - pretty sure this is the CW feeder to the HW cylinder.
So the HW cylinder must be pressurised to mains pressure (central heating feeder tank is lower than the HW feeder tank). 2 possible causes in my mind;
(1) HW cylindar coil has a leak letting mains pressure in - but Central heating is from a lower feeder tank so I don't understand how that could happen.
(2) something in the HW/CW system is leaking mains pressure through e.g. mixer tap or perhaps the shower pump I fitted 2 months ago that has started "juddering" a few days before this HW tank overflow incident.
My best guess is #2 and that it is linked to the "juddering" of the shower pump. I suspect the juddering is some form of "turn the pump motor on" sensor or non-return valve. I switched off the power to the shower pump when it is not being used... my wife first saw the problem when having a shower...
Can you suggest how to test this theory or tell me if my logic is wrong and there is a possible other problem (I fitted other mixer taps when I put the shower in 2 months ago, but the problem is only just occurring now). I did cheat when fitting the shower pump and used a mains pipe rather than pipe right the way back to the HW feeder tank (feel guilty now for the short cut! Suspect this is retribution!)
