jsm
Feb 15, 2016
28
Hi
Removed radiator from wall for decorating, then refilled and bleed all Radiators.
System now saying low water pressure
Boiler saying
1. Fill System to 1 bar.. although after topping up now showing 1.5bar
2. Bleed radiators - done all
3. Contact Installer!!..
Is there anything i can do check before calling out plumber?
Fill more water into system.
You could either have a faulty pressure gauge or a faulty pressure sensor or both.
Keep adding water slowly until something happens - or until water passes through the pressure relief valve.
If it gets to the stage of passing through the relief valve you have a problem that you cannot fix - you need professional help to remedy the problem
