ideal c35 independent
View the thread, titled "ideal c35 independent" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I just installed second zone onto my ideal independent c35 original I had one hive thermostat now I added two two port valves ( with Bypass) and two hive thermostat V3
it wired into a wiring centre looking at the wiring on the boiler shall I put back the room stat/ timer loop back in as original ?
also one zone is underfloor heating, the pump needs to go in the switch live on the wiring zone ?
Pete
Yes but your boiler should already have a cable going to the old hive this is your live neutral earth and switch in the drawing so it worked before so nothing to modify with the boiler unless it had an inbuilt timer
Reply to the thread, titled "ideal c35 independent" which is posted in UK Plumbers Forums on Plumbers Forums.
Pete st neots,
Pete st neots,
