Mar 8, 2023
uk
DIY or Homeowner
Hello ,
I have an Ideal Classic boiler ff350 which runs for 10 mins before the boiler cuts out. The circ pump keeps running at this time.
The Pump and The Three port valve have been checked and the User Stat on the front has been Changed (by a Gas safe engineer)
when the Boiler cuts out there is a definitely a click from an manual sorce maybe a relay or mechanical stat behind the casing
the over heat stat on the side does not trip.
the Boiler will ignite back on after 15mins and repaeat the cycle
Any help i can pass on to the gas fitter please
THank you
