cut your losses axe it buy a better boiler BTW if your not gsr you might find its a write off internally with this fault,anyway ......
is the fan harness burnt or melted or gone faulty by getting far to hot?Not an option, what makes you say that? I ruled out the overheat stat, actual fan, good earth to board, ignition and gas valve, its on the fan harness for sure.
Never had to change one myself but have heard that they can take out the PCB ...... And the Fan in one swoop.......!
No idea until I go tomorrow to change it, had it on a call out last night.
get an axe or a gas registered chap in to have a look or you will be out of luck.
These are an easy boiler to fix but expensive on parts
don't try fixing it yourself no matter how many things you check with your multimeter
Good bit of diagnostics zeebeedee IMO 🙂 ... What got you checking out the harness rather than just replacing the PCB?
well if its melted you will find the rear of the hex is as well caused by the ionization probes(posh word for bent bits of steel at funny angles)have fallen off the insulation panel has fallen on to the heat exchanger and the burners melted the rear of the hex,wiring and the pcb will have probably blown up because its made of chocolate
check you have also not trapped the ignition or detection wires on the cradle next to the pcb they will earth and throw up the L f codeBoard was dead on arrival, had one in the van threw it on and it started throwing a LE at me :32: Started with the overheat stat, shorted it out and still got it, unplugged the fan from the board retried it got the fan error code, quickly tried a new fan still the same, checked the lead for continuity between the colors all fine, checked all the connections against earth, and the pink threw up a short. Sadly didnt have a harness, so back tomorrow to change it, hope to christ i am right!
we have his gs number but good point should be in the arms or gsr only forumNo more open forum diagnostics or tech discussions
Move to the arms IMHO
pm dan or dave with your gs details join the gsr only forum and plumbers armsGood idea to take the burner out then and see if I can see anything untoward going on behind there!
Sorted! Wasn't that tricky in the end!
Reply to the thread, titled "Ideal icos he 15 LE error" which is posted in UK Plumbers Forums on Plumbers Forums.
