Ideal icos he 15 LE error
View the thread, titled "Ideal icos he 15 LE error" which is posted in UK Plumbers Forums on UK Plumbers Forums.
zeebeedee
Narrowed this down to the fan harness, short to earth on the pink wire, anyone had any experience changing these. They look a nightmare, runs up behind the heat exchanger!!!
Can't say i have but anything to do with this or its brother the isar is a nightmare.
cut your losses axe it buy a better boiler BTW if your not gsr you might find its a write off internally with this fault,anyway ......
Not an option, what makes you say that? I ruled out the overheat stat, actual fan, good earth to board, ignition and gas valve, its on the fan harness for sure.
Never had to change one myself but have heard that they can take out the PCB ...... And the Fan in one swoop.......!
is the fan harness burnt or melted or gone faulty by getting far to hot?
get an axe or a gas registered chap in to have a look or you will be out of luck.
These are an easy boiler to fix but expensive on parts
don't try fixing it yourself no matter how many things you check with your multimeter
I am registered, only been doing breakdowns for about a year, got bored of installs.
Good bit of diagnostics zeebeedee IMO 🙂 ... What got you checking out the harness rather than just replacing the PCB?
Board was dead on arrival, had one in the van threw it on and it started throwing a LE at me :32: Started with the overheat stat, shorted it out and still got it, unplugged the fan from the board retried it got the fan error code, quickly tried a new fan still the same, checked the lead for continuity between the colors all fine, checked all the connections against earth, and the pink threw up a short. Sadly didnt have a harness, so back tomorrow to change it, hope to christ i am right!
well if its melted you will find the rear of the hex is as well caused by the ionization probes(posh word for bent bits of steel at funny angles)have fallen off the insulation panel has fallen on to the heat exchanger and the burners melted the rear of the hex,wiring and the pcb will have probably blown up because its made of chocolate
Good idea to take the burner out then and see if I can see anything untoward going on behind there!
check you have also not trapped the ignition or detection wires on the cradle next to the pcb they will earth and throw up the L f code
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Ideal icos he 15 LE error" which is posted in UK Plumbers Forums on Plumbers Forums.
zeebeedee,
Dotty,
