C
chelsea
LF code showing up,been looking on the site but no definitive answer
cleaned condense trap and checked to make all clear and is fine, and spark electrode had to be re-positioned as slighty bent so was not sparking, it ran for 10-15 mins then LF showed up
I was thinking maybe flame sensing probe duff
Any advice would be much appreciated
I'd check the flame detection electrode too & the ignition one
If it's not sparking on start up check for 240v across blue & brown on spark generator
If you have a FGA it'll let you know if the issue is flame or flame sensing, that is if the flame is burning constantly for the time you mentioned! It the flue vertical?
Borrow gas mans axe or rip it off the wall with your teeth and stick it in the canal!
please, please don't stick it in the canal...recycle it !! the possibilities are endless, could become parts in another ideal boiler 🙂
