Ideal Icos HE24 replacement
View the thread, titled "Ideal Icos HE24 replacement" which is posted in UK Plumbers Forums on UK Plumbers Forums.
darren221980
Evening all,
I currently have a Ideal Icos HE24 boiler in my house, i've been in this house 3 years in June so the boiler will be 10 years then so from what i understand with these boilers its had a good life.
Anyhow for the last two winters this boiler has had constant problems, usually with the L/F fault. The condense pipe gets blocked up and i was also told when i had British Gas quote me for a new boiler last summer that the condense pipe outside my house is in the wrong location and should be going direct into a drain or even a outpipe under my kitchen sink which is pretty much next to the boiler.
In the service i had last year i was told by Scottish Power that the boiler is beyond economical repair if any parts go on it again. And in the last month the L/F fault has returned which has so far been fixed by just holding the reset button for 2 seconds.
So i need to look at getting a replacement boiler especially before the winter months return. The house i live in is a 3 storey house, with a shower and 3 radiators on the top floor. The middle floor has a bath and 5 radiators while the bottom floor has 4 radiators. The current boiler sits inside a cupboard in my kitchen which may limit what replacement boiler i can actually have fitted. With the cupboard door shut the maximum depth any replacement boiler could be is 32cm, the height 75cm and the width 60cm.
The initial quote i had from BG last year was for a Glowworm Flexicom 18SX along with a horizontal flue terminal, internal condensate connection, connect boiler electrics & test, installation, flume displacement kit, install gas pipe work (22mm x 3mtrs length), pipe concealing kit, install hydroflow HS38 scale reducer, system water treatment and powerflush, install 22mm magnetic system filter, and finally Remote control heating. BG quoted £3606 for this work which i didn't have at the time and i wanted to get several quotes before getting a replacement anyway.
I'm due to inherit some money in the next few weeks so want to use some of it to get a replacement boiler fitted.
So my question is, can anyone in the know advise on some suitable replacements to go with for a new boiler?
Thanks,
Darren
Ideal logic 35kw. Straight swap and comes with a 7 year warranty. Alternately if enough room ideal vogue 40kw.
Lot less than BG! In fact for £3k I will do it tomorrow.
Get an independent in as big companies rip u off .
For about £3500 u could have unvented
Hi darren, welcome to the forum.
everyone will recommend the boiler that they prefer so here goes,
Intergas - Smart Choice
get a few local gas engineers to quote you and then take your pick.
you will likely make a saving on the BG price.
Evening all,
Thanks,
Darren
glow worms are tat,and that quote is extortionate,if the space the boiler is currently located is large enough get a baxi duotec 24HEA combi,it can be wired up to a system set up with just one outlet used for hot water,in short it will run a pressurised or gravity cylinder as you have now just needs one hot tap connecting to it as your sinks close its quite easy to do,that way you will get a proper reliable boiler that will probably be cheaper to buy than a heat only and you get a 7 year warrenty so you can bin your bg contract
thanks for all the replies so far guys.
I though the quote from BG was quite expensive and over the top myself, was quite shocked with it to be honest.
Anyhow, i was under the impression that a combi boiler wouldn't be ideal for a 3 storey house, as the water pressure may not be any good for the shower on the 3rd floor. Is this correct or bs someone has told me?
Thanks,
Darren
Reply to the thread, titled "Ideal Icos HE24 replacement" which is posted in UK Plumbers Forums on Plumbers Forums.
darren221980,
darren221980,
