Ideal Icos m3080 LE then L8 error code!! Do I repair or replace
View the thread, titled "Ideal Icos m3080 LE then L8 error code!! Do I repair or replace" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
E
eurospike
Hi woke up this morning and no heating :-(. Error code on the boiler was LE, then I reset it and now get error code L8. Have been reading the forums and looks like I need a new PCB and maybe a new fan assy. Plumber is quoting around £500 to replace both parts.
The boiler is about 7-9 years old so should I repair it or fit a new boiler?
The PCB did fail on install apart from that has worked OK.
Other question is could I fit these parts myself as I have fitted a complete central heating system in my last house about 15 years ago? I can get the parts for lees than £200 on ebay.
Any advise would great Thanks 🙂
The ignition electrode (if faulty) can sometimes cause a very strange fault on these boilers. It starts off on a board fault, u replace the pcb, it then gives u a fan fault code, u then change the fan, reset it again and it gives u the pcb fault code again, ideal are aware of this fault. I'm telling u, try the ignition electrode in the 1st instance, it's much cheaper than the other 2 bits. And yes I've had this fault twice in the last yr
I wouldn't reccomened that the op does the work
Id say you should get a GSR in
Hi many thanks for the input from everyone. Now have had the PCB, fan(which was very stiff compared to new one) and the ignition electrode replaced. Now have error code "HE" displayed :-( do you think the new PCB is faulty? Is there anything else that could be replaced? starting to cost me a fortune in parts and labour and no one really know what it could be.
Reply to the thread, titled "Ideal Icos m3080 LE then L8 error code!! Do I repair or replace" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
eurospike,
eurospike,
