Dec 28, 2012
910
What's the difference between the ideal independent and ideal logic boilers, the logic is a fair bit dearer is it worth the extra?
Independents are a bit nastier looking and hardware pack has no filling loop or tight radius bends.... Hydro block is plastic. Logic plus is a whole different ball game though. I would if custard had enough try logic plus. If LL independent 24kw!
What do you mean by no tight radius bends?
Thank you. The logic is about £130 pounds more. Was asking as I'm sure I read somewhere it was just the same boiler inside. Maybe I heard wrong?
It's like buying a skoda because it's the same as an Audi. Good quality but slightly different. Unless u were an expert you wouldn't know difference if case was missing.
i have a fault with my ideal c28 combi loosing pressure can anyone suggest what could be causeing this
