Guest viewing is limited
View the thread, titled "Ideal Isar HE24 problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
Matty7
Hi
I am gas safe registered but I mainly deal with installations and only slightly delve into the fault finding/ diagnostic field. Ive had a problem with my ideal Isar he24 combi boiler, (boiler was already in the house when we moved in 6 months ago) It was showing a fault code of flashing f-l which after much searching I narrowed down to a blocked condensate trap (a common problem judging by these forums) basically when I removed the trap the sump was full of water and once removed I realised the trap was completely blocked. I have replaced the trap and there is a nice flow through from the sump to the condensate now. All I am asking now is the boiler seems to be slightly hotter than I would usually of thought it should be with the pump very hot to touch, and there is absolutely no condensate in the sump now once it has been running for a while, but overall the boiler seems to be working fine. I just want to ask is the sump meant to be bone dry? Like I said all seems to be working fine, and when I turned the boiler off last night it was completely cool this morning, All I was thinking is, is it overheating or does this sound ok? Hope this makes sense and thanks in advance for the help.
Matt
Hi. You will have to supply your gas safe credentials to a moderator for gas advice.
It wont be given out on open forums, only the private gas safe registered forum.
Regards
Thanks Newcastle phill. I'm new to this site so will do that now, can you direct me how to do this though?
Matt
Hi Matt welcome to the forum please get your post count up to 10 and private message gas man with your gas safe details.
Reply to the thread, titled "Ideal Isar HE24 problem" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Matty7,
Rickster123,
