View the thread, titled "Ideal Isar HE24 water not hot enough when tap open to maximum" which is posted in Bathroom Advice on UK Plumbers Forums.
R
r05h4n
My boiler stopped working recently secondary to a PCB fault. I got it replaced but since then my hot water is not hot enough when turned on to the max. It used to burn me! Now its just luke warm.
The heating is fine and the water does get hot when I close the tap to about 1/4 of max.
Any ideas whats wrong with it? I miss hot showers!
It should be on 1 - 1.5 so you have too much pressure for starters, if you have had the PCB replaced then I doubt it will be a problem with that. I know its a silly question but is the hot water stat turned up on the boiler?
Reply to the thread, titled "Ideal Isar HE24 water not hot enough when tap open to maximum" which is posted in Bathroom Advice on Plumbers Forums.
