Ideal Logic boiler
View the thread, titled "Ideal Logic boiler" which is posted in Gas Engineers Forum on UK Plumbers Forums.
I have an Ideal Logic boiler, and I noticed that the display screen does not stay on all the time. It only lights up when I change settings or when there's an error. However, a gas engineer who visited my home claimed that something was incorrectly connected because the display should stay on constantly.
From my understanding, the screen on Ideal Logic boilers normally turns off after a short period of inactivity, unless:
There is an active error code being displayed.
The boiler is in a specific mode, such as pressure testing.
You are interacting with the settings.
Everything seems to be working fine, and the heating/hot water functions as expected. So, is the screen turning off actually normal behavior for this model? Or could there really be a wiring issue as the engineer suggested?
What’s the error code and by display do you mean the writing or the backlight ?
There is no error code on the display. My previous gas engineer told me that the display should stay on all the time, but on my boiler, the screen only lights up when the boiler is actively heating water or running the central heating. When it's not doing anything, the display turns off. Is this normal behavior for an Ideal Logic boiler, or could there be a wiring issue?
Normal
Reply to the thread, titled "Ideal Logic boiler" which is posted in Gas Engineers Forum on Plumbers Forums.
lunnared,
ShaunCorbs,
