IDEAL LOGIC COMBI 30, hot water not very hot
View the thread, titled "IDEAL LOGIC COMBI 30, hot water not very hot" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Can we have some more information please is this a recent occurrence how old is the boiler is there a filter fitted a picture of the boiler would help ?( Your boiler will only raise the cold incoming temperature by 35 degrees the recent cold snap could quite easily have lowered it to 2-3 degrees does the water get hotter if you slow the tap flow down ? Does the boiler go on then off repeatedly when the hot tap is turned on ? Regards kop
Thanks for the reply,
Additional details as follows
Boiler age about 8 yrs, flow is good, the problem has been with us for about 2 months, boiler stays on continuously not cycling, water temperature is 38c
I have reduced the flow rate but no difference
Regards
Reply to the thread, titled "IDEAL LOGIC COMBI 30, hot water not very hot" which is posted in UK Plumbers Forums on Plumbers Forums.
Retired Plumber1,
Deleted member 120897,
