Guest viewing limit reached
Ideal logic heat 18 not working
View the thread, titled "Ideal logic heat 18 not working" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I'm having issues with my ideal logic heat 18, it was showing fd error code so I replaced the flow sensor also thoroughly flushed ot the heat engine and pipe work, it will run fine on service mode but will not fire up unless the heat exchange is tapped lightly then will shut down when tapping stops, any help gratefully recieved
Reply to the thread, titled "Ideal logic heat 18 not working" which is posted in UK Plumbers Forums on Plumbers Forums.
Flaxxx,
SimonG,
