R
reedy77
Had the above boiler installed in March, been working beautifully....
However, yesterday morning no heating or hot water. So called out the installer. To his credit he came out within a few hours and spent an hour or so trying to find the fault. He was reluctant to start fiddling to much as he did not wish to invalidate the manufacturers warranty. He did check that the pump was not stuck.
The message on the screen is :-
No water flow lockout - 1 fill system to 1.0 bar - 2 bleed radiators - 3 check radiator valves open - 4 reset boiler - 5 contact installer.
To confirm the system is at 1.5 bar. No air in the system, all rad valves open....
Rang Ideal this morning, who said yes will come and fix your boiler on the 4th January, great quality service....not when i'm asthmatic, my wife is preggers the daughter is just getting over swine flu! So hence would like to get the house warm. (I did incidentally explain this to ideal who just said 'oh, can't do anything'....
Any way had a look through the fault finding chart i have checked connecttions on:-
The no flow thermistor
The control thermistor
The return thermistor
All appear to be fine..
If i get someone to fix it will it invalidate my warranty? Has anyone else had this problem?
Any help/suggestions would be much appreciate...
