With these flush valves you can remove them just by twisting them at the body, water will run down the bowl but check the bottom rubber that’s most likely the cause if not it’s the diaphragm scaled up. Changed 3 about a month ago
Reply to the thread, titled "Ideal Standard running into toilet Bowl cistern-fill-valve-sv81767 ?" which is posted in Boiler Advice Forum on Plumbers Forums.
