J
jirams
Gravity Indirect HW cylinder fed by Baxi 552 BBU + circulating pump + 9 rads.
Are there any 'standard' symptoms or 'tests' that would confirm (or otherwise) that the heating coil in such a system was leaking into the HW part of the cylinder?
There is no evidence of expansion into the F+E tank nor expansion of the HW system.
The reason for ? is that when the boiler is burning, I hear noises which sounds like air causing turbulence but all the rads do not need bled and as I said above there is nothing being ejected from expansion pipes. I don't hear the noises in attic - they are heard downstairs in house and with ear against chimney breast adjacent to pipe runs to BBU.
