N
Nik
Good Evening
I would like some more help please, to avoid further issues, suprises and expense.
Re: -inlet-valve-cistern-will-not-sit-tight-to-bottom-of-cistern
Following my post yesterday, I considered the possible outcomes of cutting the pipe.
Thankfully, it is a weekend and snowing, not a good time to be cutting a pipe with an elderly disabled mother in the house.
I will therefore be calling a plumber out to fit a ballofix, flexible hose (female to female) and an inlet valve.
I have already purchased the inlet valve (copper olive, plastic washer and tape, if needed).
So he will need an isolation valve and a flexible hose?
Will I have to pay for parts on top of the £80 labour?
Should I disconnect the cistern from the toilet? Remove the overflow pipe and disconnect the saniflo. Basically disconnect everything that is connected to the cistern and pan.
So the plumber will have to reconnect everything. Just so I can be sure that nothing else can go wrong after they leave.
I would be very grateful for any advice as I do not want to offend the plumber, but need to be sure that it is all done and I do not end up being made a fool of again. (please see my last comment on my previous post).
