Aug 7, 2019
Cardiff
DIY or Homeowner
Should it be possible to add a couple of washing machine style tee valves in the middle of these copper pipes?
Forgive the basic question, but I am an inexperienced home owner. Thinking of giving it a try myself today.
Would this risk reducing our tap water flow from the pipes continuing above, or any other potential issue?
The type of cutting in devices you are proposing are really not very good. They restrict the flow just to do with the restrictions necesssary to be functional. However properly fitted they hopefully
1. will not leak 2.will supply water at a suitable pressure and volume
3. will not leak over time. Its a one hour job for a competant plumber
to set the system up properly...I would go that way ....centralheatking
  • Winner
Reactions: rpm
arnt you using these?
https://www.NoLinkingToThis/p/compression-appliance-tee-brass-x-x-15mm/24030
or
https://www.NoLinkingToThis/p/washing-machine-valve-tee-15mm-x-15mm-x/60723
dont use the self cutting ones
Reactions: centralheatking
