View the thread, titled "installing a back boiler oil link up in a bungalow, anyway around it?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
may be more use http://www.solidfuel.co.uk/pdfs/link_up.pdf the previous link shows systems not allowed in the UK
I think you are referring to the heat leak radiator being ommited on the schematic.
From the sfa.....
The heat leak radiator is not a safety device but serves to reduce the risk of water boiling and discharging into the header tanks and out the overflow. I am not aware of any legislation which covers this issue.
MI's always superceeds the regs in any case.
From the sfa.....
No it is the solid fuel boiler in the link which is on a pressurised system
you have to think of others looking at this thread and thinking its ok to put a solid fuel boiler on a pressurised system, as this thread is about linking solid fuel to oil
There's nothing in the link to suggest connecting a solid fuel boiler to a sealed/pressurised system. What link are you looking at?
But since you mention it, it is OK to put solid fuel on a sealed system in the uk. Broseley fires for example have scws fully approved for use in the uk for solid fuel stoves engineered appropriately.
near all finished just need to connect pipes to boiler and fill the system! 1 more question the customer is now putting a harth around the stove and he was asked me to move the pump up above the ceiling into the roofspace, was thinking of putting it on the return to the stove,the only thing is that i have the feed and expansion on the flow out off the stove would this cause any problems?
What way do you have it piped? Have you used 4 pipes, ( 2 for gravity, normally 28mm & 2 for pumped circuit).
The gravity pipes should have a vent on flow & a feed on return. No valves or pump.
no i went the fully pumped route customer didnt like the idea of his new wooden floors being ripped up, he was happy enough to go ahead with it fully pumped! i ust have 2 pipes going to stove and i have the cold feed and the vent coming off the pipes when the enter the roofspace! The pump isnt blocking the vent as it is on the return to the boiler, i have a 22mm vent and cold feed coming off the flow pipework 100mm apart!
Not a way I would think of doing it. Assume you took the pipes to cylinder & then rads. That means the pump is on the gravity return, near to boiler?
Fit a gravity heat leak rad of the correct size, if the power goes off the heat has somewere to go, it is not a requirement to have gravity to the cylnder as long as you can get rid of the heat in a rad
I would advise a fire to have a gravity circuit bare minimum with flow having a vent, return a feed pipe. Some systems have been done with a pumped circuit teed to gravity circuit. At least this is not dangerous.
Gravity return? as i said there is no gravity circuit, the two pipes just link into the existing central heating pipework where te flow and return enter the property! yea the pump is on the return to the stove near the stove and feed and expansion is on the flow from the stove???
I'll not lose any sleep over you that's for sure lol
You want to be a cowboy that's upto you
Water being heated from a fire must rise, as on a gravity circuit, or be pumped constantly, BUT, you can't rely on a pump & you really shouldn't have valves on gravity pipes in case they fail or some idiot closes one accidentally. Hence gravity is the only way. If fire is going full belt & the pump stops for any reason, the boiler will come under a lot pressure, & I wouldn't want to be in the house.
The stove manufacturer will not accept your install, I am sure.
Reply to the thread, titled "installing a back boiler oil link up in a bungalow, anyway around it?" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
Mr Flux,
Lou,
