View the thread, titled "Installing upstairs toilet soil stack" which is posted in Boiler Advice Forum on UK Plumbers Forums.
K
kjsmith1701
I have installed a toilet upstairs and completed all the pipework, I am now ready to run the soil stack down in line with the downstairs wc. Can I run the upstairs toilet soil pipe directly (which runs straight down) into the downstairs toilet connections via a u-bend to discharge into the main (not the d/s toilet)(which would be a lot easier than breaking up concrete to find the mains) or do I have to connect it to the main sewer pipe? would appreciate any advice, many thanks.
If you can connect D/S toilet into side of Tee piece then U/S can be connected into vertical part of Tee. Use Tee again for U/S connection, rise above basin level and finish with AAV.(Air Admittance Valve).
That's great thank you for your advice and replying, sorry to trouble you further but will this all be okay with building regs? thanks kate.
Do you mean is it correct or do you have to notify building control?
The d/s wc soil connection is on the inside and goes straight down under the floor, there is no external soil pipe other than what I am installing. My preferred option is to run the soil pipe from upstairs vertically down in line with the d/s wc and then connect to the vertical of a tee (as suggested by joni os) however as the soil for d/s wc is inside, I would have to run down vertically then come in to fit the top of the tee via a bend - this is the bit I am unsure of as I have been advised that there should be no bends?? I want to sell the house when all the work is done so would not want anything flagged at that stage. any advice really appreciated - many thanks kate
I think I know what you mean but it's difficult to picture without a photo or diagram. If you can post one then that would help. Other alternative is speak to building control as I believe they must be notified about a w/c upstairs that wasn't there before.
Reply to the thread, titled "Installing upstairs toilet soil stack" which is posted in Boiler Advice Forum on Plumbers Forums.
