View the thread, titled "Instant hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
M
mrlennie
Hi I have been asked by a customer to install 2 hot water heaters for kitchen sink and bathroom with a view to removing vented cylinder. My question is what appliance do you recommend?
Also I have not looked at their electrical supply yet but I'm guessing they don't have much spare so low KW is a plus.
I'm afraid you'll need an unvented ticket - or have you got one? Hopefully that's not too cheeky a question or comment.
Assuming you have the qualification, how big is the house and why two heaters? Won't a combi boiler do? Or a hot water cylinder on Economy 7?
Hi no I don't have the ticket but I was under the impression you could get one like the way an electric shower works. It is only a small thing that works when you turn the tap on.
The house doesn't have gas.
Thanks for the response dontknowitall
Is there space for gas canisters or an oil tank? Obviously if it's a two up/two down this is overkill but if it's a 3+ bedroom house then this is a viable option.
Cheaper alternative (to install but not to run) is to have a hot water cylinder heated by immersion heater(s). How do they get their hot water and heating at the moment and what size of property is it?
(Thank you for the thank you - always appreciated!!)
No the idea is to get rid of the vented which is heated by immersion heaters. They have an electric shower and two bedrooms. The cylinder is in the bedroom and they want rid and a simple box underneath the sink to heat the water. The taps are rarely used and needed just for hand washing if that lol.
A little under sink unvented heater is probably the best but you can get over the sink heaters (those boxes with ugly spouts). Unfortunately for you, you'd need a ticket for the under sink option. And it would need to be large enough to provide heat for the kitchen sink and bathroom basin and installed somewhere so it can vent to outside.
Hope this helps a little but sorry I can't be more positive.
you dont need an unvented ticket for 15l undersink water heaters and a 3kw ariston one will easily supply a sink and basin, which is ok if they have an electric shower for bathing. have lookon the net for prices and ensure a sparky wires it in correctly and use a decent plumber to put it in who knows his stuff, if you feel you need more than 15l storage then an unvented ticket is needed and cost rise quickly for bigger cylinders
You could use a Redring Powerstream which is available in 9.5, 10.8 and 12kw. Basically an inline heater which works like an electric shower. Very compact and neat looking and don't need any additional controls or exp vessels etc. Cost around £120+vat.
You will need a decent electric supply if fitting more than one or it can be done using contactors. Not sure how it is done exactly but a decent spark would know and advise. They will supply up to 2 basins or a basin and shower. Used to fit them on petrol stations as they only supplied a sink and a basin. Worked good enough.
Zip and Sadia do them too.
Apart from that you are looking at an undersink heater.
Oldplumber and Tamz - thank you for those snippets. I didn't know how good these smaller units are. Obviously not good enough for a bath but now I know.
Reply to the thread, titled "Instant hot water" which is posted in Bathroom Advice on Plumbers Forums.
