king of pipes
Subscribed
Dec 20, 2016
6,156
4,335
113
63
Norfolk
Heating Engineer (Has GSR)
Just did a conversion from heat only baxi 80e and old bare copper cylinder to the Intergas all went ok gas was in a mess so between myself and Cadent got it sorted , fitted the one touch smart control was so easy to set up connected first time , customers happy with his app , i have the installer app so can monitor the boiler even make adjustments to the setting sends a message if theres a problem , doing the Intergas training course tomorrow can give the customer 10years warranty and has its benifits . cheers kop
Intergas say because of the way the water is heated via the main heat exchanger and your pipework rises to above if you dont fit a NRV in the return in the summer when theres no demand for heating the boiler can thermo syphon up into the radiators when there is a call for hot water , elbow on the condense shaun ? is a mcalpine adaptor cut down with a white rubber in i did open it up with a 25mm hole saw minus the drill bit of course theres enough plastic to do it keeps it looking tidy bud . cheers kop
