T
thewatergirl
There is a problem with my water heater. I keep losing pressure from my hot tap. It's on all taps so I know it's not a air lock in the tap. I also know it's not the mixing valve as the died a couple of months ago and was replaced. What happens is the water coming out of hot tap is just a trickle. The trickle is cool so it's clearly the cold the blending valve mixes in so i don't boil alive in the shower/bath. It comes back on if left for a while. There seems to be no set pattern to this. It happens a couple of times a day although as i'm only in morning/evenings I suspect it would be more frequent if I used water more often. I've had my immersion looked at and there seems to be no obvious problem. Nothing is missing/broken/damaged etc. The immersion runs on economy 7 and my house is all electric I have no gas heated hot water. When I turn the boost switch on the hot water was running fine within 10mins. I thought this was just coincidence. I left my boost on accidentally for three days this week and not once did I have a problem with my hot water. I noticed and turned boost off and the problems started again. The two things must be related? I've tried googling and it suggests the mixing valve is faulty or an airlock in my tap. I'm stumped. Any suggestions anyone please?
