Is it mechanical OK to replace a Wilo Gold SR50 pump with a Wilo Gold SR60's ?
View the thread, titled "Is it mechanical OK to replace a Wilo Gold SR50 pump with a Wilo Gold SR60's ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
O
OCDRAGON
I'm thinking of increase the flowrate of my existing heating system but keeping it simple for an outsider like me. As a result I'm thinking of "lifting" the electrical and moving part of my existing Wilo Gold SR50 pump and replacing it with a Wilo Gold SR60 pump's part instead, while keeping the base part of the SR50 pump's port-to-port unchanged. Which means ALL pumpings would be unaffected. So the basic question is
Are the Wilo Gold SR50 and SR60 are mechanically compatible, i.e. both Wilo Gold SR50 and SR60 bases are exactly the SAME part and so do their two fixing screws for fixing their top electrical/moving parts??? Since I haven't got a Wilo Gold SR60 to compare, I would be much appreciated if anyone can comment that!
Thanks:confused5:
Why do you want to I crease the flow rate of your system?. You may cause mire problems than you cure depending on several factors such as how its piped, levels of sludge, position of vent, height of f and e and so on.
I have no problems with my existing system but the water pump Wilo SR 50 is getting old and hence I am thinking of replacing it. As it happens the Wilo SR 60 is a bit more powerful, its flowrate can be adjusted and roughly not costing too much. That Is why I'm think of just replacing my SR50 with the SR 60 provided it has "identical" base-part which does not affect my pipe-work.
being as your an outsider and admit to it, the simple thing to do is leave well alone, you'll regret messing in the long term. Someone has already planned your system, proved it works and been paid to that effect years ago.
Hello, thank you for your frank suggestion. I will leave my system alone as you said, thank you once again!
Reply to the thread, titled "Is it mechanical OK to replace a Wilo Gold SR50 pump with a Wilo Gold SR60's ?" which is posted in UK Plumbers Forums on Plumbers Forums.
OCDRAGON,
OCDRAGON,
