Hi Chaps, wow Am I having some serious issues with air. Basically, my pump went a couple of weeks ago. Just starting screaming really loud. So, i flushed the system and bought a new pump.
Now, i cannot seem to get rid of the air. I have changed pump setting. The old pump was on 3, and i had it on 2. Heats up the house fine. So i tried 1. And the rads do not get very hot. So, I have just kept it on 2. The problem is though, it just keeps filling with air.
Today, I have changed it to a close coupled system, hoping this would help. But if anything, it is worse!! Also, it is always the same radiator that needs bleeding. Could this be the problem?
I have checked for pumping over, and air being drawn down the vent and all seems fine.
The reason I ask if the heat exchanger in the boiler could be causing it is, It seems when the water flows through and up out of the boiler, a gurgling noise is created.
The layout of my system is this. I have a Boiler in the kitchen with the flow and return pipes going up into the loft and down into the airing cupboard where the pump is positioned pumping down(i know its not supposed to, but that is how it has been). Then it goes into a mid position and so on.
The F&E tank in the loft is situated on the floor where the flow and returns run, and the cold feed and vent are connected behind the pump close coupled.
I have filled the system from the mains into a drain cock, but no help.
All i can think of to do now, is convert to a sealed system. But, am afraid i might blow all the old pipe work out of its fittings.
I am struggling
I am struggling
