View the thread, titled "Janus Water Heaters" which is posted in Bathroom Advice on UK Plumbers Forums.
diamondgas
Hi peeps,
For the past 2 years I've had to remove the hex on a Janus 3 and clean out the build up of debris inside. 22mm F&R with a 7yr old Direct Cyl fitted in Airing cupboard directly above. It's a common issue I've dealt with for years with w/air circulators. However I was just wondering whether any of you have heard of any kind of filter or collectors that can be fitted in-line? It'd save a lot of grief I'd imagine if it was just a matter of isolating and cleaning that out rather than having to strip the whole circulator down! This is not a hard water area by-the-way!
I'm there tomorrow so I'll see if I can get some pics to show you...!
Any thoughts :lightbulb: in the mean time will be appreciated ... :smart:
I thought of a magna but then I thought it'd restrict the gravity circulation too much and the valves and such would block relatively quickly I'd imagine. Cheers though! The Janus is the circulator you find in side a warmair unit ... 😀
mfgs, that might be the ticket 🙂 Maybe even put an 1 1/4" and bush it down! Cheers. Will have to check out space within the unit but that might do the job!
Reply to the thread, titled "Janus Water Heaters" which is posted in Bathroom Advice on Plumbers Forums.
