Thats a cracker, but did u notice it was discoloured water no big bit swimming about ,, theyre drainage is slightly different to ours , they dont usually put loo roll down inside the pan as theyre drain pipes are smaller in dia to ours,,,, GREAT VID alex nightmare if the guys hand went through when pushing,,
On most uk pans would some of it not be forced up in to the cistern through the flush hiles in the pan. A close coupled drop flush valve isnt going to hold that back. Then its in the bowl and the cistern and hasnt shifted the sh. It
At least with a plunger you can use it more than once. Who wants to be the one to roll this up and take it to the next blocked toiler?
Can just see the crapachino trothing out around the doughnut on a close coupled throne
