View the thread, titled "Jobs you hate doing." which is posted in General Plumbing Jobs Discussion on UK Plumbers Forums.
M
Mikey456
Seeing as we've got a favourite jobs post the things you hate doing
Coring Holes
Cementing round holes
Changing toilets
Changing taps on baths when its extremely tight and you feel like smashing the bath to bits.
Oh jeez dont even remind me, working on a 24CDI to replace the diverter valve. Heat exchanger out, filling loop out, lots of little pins to pull out. Then after getting it all back in it leaks stupid plastic parts! no amount of PTFE or gas seal would stop it from leaking must of had everything in and out of the boiler at least 5 times. We refuse to work on them anymore ended up replacing it with a baxi 105
changing bath taps for sure can be a nightmare, would rather change the complete bathroom sometimes then try to swap the taps when in a tight space.
Soldering, pushfit, compression fittings, taps, WCs, radiators, heating, cylinders, wiring, painting, woodwork, paperwork, driving, talking to customers ...
Changing PRV's on the new Worcesters - sack the designer!!!!
Also don't like changing the ignitions probes or burner gaskets on Ideal Isar/Icos. Hate it!!
is that the one,were you cant get at one of the nuts,screws on the right hand side on top of exchanger, there should be a special tool for it, at the very least
Done one wednesday brick wall drilled a pilot hole went through proper easy thought this'll only take 10 mins, came to coring it then took us an hour n a bit engineering bricks the dust kept jamming the thing 🙁
Its a nightmare matey! I just use my 8mm ratchet spanner and swear my head off!
Tidying my Van , it takes ages and doesnt earn my anything ( allthough I suppose if I didnt muck it out occasionally I wouldnt be able to work ) !!!!!!!!
excellent verdigrey my pet hate i have to change vans next week not looking forward to it
I love tidying my van and giving it a good clean with the pressure washer. Its amazing how much you find when you clean it out. I tend to find loads of change and lots of lighters and it always amazes me how the rubbish from McDonalds seems to hide everywhere!
Driving, changing syphons on WC (the older type where you have to remove the whole cistern to do so), lagging, shower doors and enclosures, bath panels, triple ladders, working in lofts where they've had the insulation increased to the new recommended height and it's laid across all the joists and pipes.
Generally don't hate too much of our job. Lucky really. Oh I do have one BIG hate.
PAPER WORK!!! ARRRGH!
working in scruffy rented propertys changing bath taps with your head rubbing against the chatty toilet bowl that has never been cleaned, urine smells ouzing from the non covered t&g flooring. finding chicken bones and rat droppings strewn behind the bath panel as you remove it.
or concealled toilet cistern i did the other week, removed panel and there was around 50 used condoms in a pile in the corner just where i needed to work. told the woman to move them, unlucky for her she only moved in the day before.lol.
ah yes, answering the phone, rather be sent to a job than arrange and price it.
That is hardcore gross. I don't get grossed out easily, but a pile of used condoms. Think I'd have walked. Good on you mate.
Reply to the thread, titled "Jobs you hate doing." which is posted in General Plumbing Jobs Discussion on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Thread Tags
Mikey456,
Dan,
