for small jobs i tell the customer over the phone my minimum charge, they either take it or leave it. Your minimum charge should be at least time and a half, or mostly double time for emergencies
No point having a rant. Put in a quote for replacing and see if you get the job - if you do then you know they didn't think you were too expensive.
To see it from the other guys perspective he may have expected one bill for the completed works at the end. Or he may have been shocked at how cheap you are! Another thing I find with older people is they also aren't quite aware of how little a £ is worth these days and he's probably looking back 50 years.
Emergency call. Leak coming through ceiling. 40 gallon CWSC sitting on chipboard buckling so bad it probably had minutes left before it came through their ceiling. Didn't discuss price, just set about draining it pronto through taps and through syphoning via hose into buckets. Cut cold in, add isolator so they can put water back on. Remove connections to cistern, pull to one side, confirm base crumbling to pieces. Measure up for replacement. 1hr 15mins.
£50.
"Really? That's a bit steep isn't it?"
You undervalue yourself mate, you did the job for a low price. The guy is a waste of space and you're lucky to lose him as a customer.
The bloke just phoned me up to have another go. I left a message on his answerphone on friday asking him to phone me if he wanted a price for finishing job but saying I might need to order a tank to fit the space. He phoned me specifically to ask me to repeat my message to him, which I did and then told me he'd bought one himself, done it himself and then said bye and hung up. The guy must genuinely think I'm a con-man and is still reeling from my £50 charge. And now he's done it himself without getting any quotes and seeing how much plumbing work costs he will go on thinking this. Wonderful. I've half a mind to print this thread off and post it through his letterbox.
sounds like a tight arsed old git
Reply to the thread, titled "Just been accused of being a rip-off merchant." which is posted in UK Plumbers Forums on Plumbers Forums.
