keston celsius 25
View the thread, titled "keston celsius 25" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Viper Gas
Hello All,
was called to a keston celsius 25 to check escape of gas.
I found gas escaping from a broken fan seal as the boiler was running.
The gasket was replaced but now the boiler will not fire up.
tried it many times until and eventually it fired up?
it was running sweetly but then i decided to turn the boiler off so i could connect manometer to check burner pressure and now it wont fire up again???!
does any one have any clues here????
blocked condensate?
block exhaust flue?
all air purged from gas pipe work?
theres a little test point which says VENT on the gas valve, if this gets blocked, say with detection fluid will this impede operation of gas valve?
cheers
D368
if its a vent and its full of detection fluid that might not be helpful, get your air duster out
I had this problem with a worcester greenstar after I'd serviced it, turrned out I'd knocked a little grey rubber bung off a vent point on the gas valve! Stuck it back on fired up no problem! Could be the same valve
my normal trick on baxi 105/80s is to pull off the flame sensor lead slighlty so it stays in the rubber sleeve but not on the metal contact, but I seem to do it so often I can spot the problem quickly now!!
Reply to the thread, titled "keston celsius 25" which is posted in UK Plumbers Forums on Plumbers Forums.
Viper Gas,
lame plumber,
