Kitchen Mixer taps dripping
View the thread, titled "Kitchen Mixer taps dripping" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Posted in the shower forum and the advice I got was excellent so hoping it's the same for my tap problem
I have mixer taps in the kitchen which had a drip now is a small constant flow of water.
I've tried undoing the stem and pulling it out and there is no chance it will come out.
I was advised that it would be the washers on the on/off handles
I've undone the screws and removed the handles and taken of the cover to show the nuts to undo, I cant get them loose, there so tight. There that tight I'm scared off snapping the tap.
Is this normal or I'm I doing something wrong.
Thanks in advance
sorry
hope this helps
I can get the chrome outer shrouds off too
The nuts underneath the shrouds are so tight. even sprayed with a release agent but still no movement.
I was on one spanner and my son was on another so we could try and undo them at the same time to keep the tap from bending but still they wouldn't come loose
I get you now
You need a bit of force to undo them as there prob scaled in you can't hold the spout either as that would damage it
Only thing I can suggest is either change the tap
Get a plumber out to change the cartridges
Or give it one last try and give it some welly while trying to hold against
I find a socket and wrench and if it won't budge then try tightening it and then the other way. Its as much force as you dare put on while trying to keep the tap from bending the sink.
Yorkshire Dave Can I ask why that would help ? but the answer is Chester
Because you will need new cartridges to fit your tap as there are no washers to change. As there are approx 5000 different types you need someone to make you the correct ones.
YokshireDave. so your saying when and if I remove them I will need to get new ones as there are no washers.
Think I'll be better changing the taps as suggested before
They're ceramic disk cartridges. If you're lucky there's a couple of the more common ones on sale in most merchants and sheds. If you're not lucky then you'll need to do a lot of digging to find the right ones or there is a way to make the right ones with a kit some plumbers have (Made in Yorkshire by someone called Dave🙂 )
Reply to the thread, titled "Kitchen Mixer taps dripping" which is posted in UK Plumbers Forums on Plumbers Forums.
Markdillon,
Welder,
