Kitchen sink waste foam washer
View the thread, titled "Kitchen sink waste foam washer" which is posted in UK Plumbers Forums on UK Plumbers Forums.
When putting the waste in a kitchen sink. Do people usually use the foam washer that goes on the top side of the sink and the waste. Or throw this and use clear silicone?
No get foam washer and throw as far away as humanly possible!
I have always used plumbers mait, never had a problem but it's a bit like marmite!
Those foam washers are worse than useless. I found some thin rubber ones the same size which work great.
I usually use the foam washers on the kitchen sink But silicone on the basin
I don't know why just always have although I can't see any problem using silicone,
And if the washer squeezes out just trim it with a Stanley knife
when you think about it, why do you need to use anything? as long as you properly silicone everything underneath. where's the water going to get out? goo accumulates under rim off top part of waste so no washer makes this less likely. i just silicone but have started to think nothing might be necessary
Use the foam washer that comes with it. It does its job ie stops the water emptying when the stopper is in and they won't notice it doesn't work unless she steeps her bras in the sink.
Basins are a different kettle of fish. Throw the washers to *** and use silicone or whatever you like. MI's my arse.
Why would the foam washer stop the water emptying and also why would you want it to?
If you don't seal the top of the grating and put the stopper in the water will seap under it and run down the drain and empty the sink or basin or bath or whatever. You won't have a leak as such cos it runs down the drain.
Reply to the thread, titled "Kitchen sink waste foam washer" which is posted in UK Plumbers Forums on Plumbers Forums.
Mgrant,
Masood,
