Dec 27, 2019
DIY or Homeowner
I have encountered a problem. My shower tray was leaking and I found out it was because the tray was flexing and causing a gap at the seal. I thought this would be an easy fix and have taken the seal off. Turns out this is not the case as the gap between the seal and the tiles is about 1cm tall. And also quite deep. I was thinking I could either grout the gap and then seal it or even expanding foam and then seal? I'm just worried this won't be a decent/permanent fix. What are your thoughts?
A right mess. To me it looks like a void behind that gap. If this is the case then unless your willing to take out the tray and start again then what ever you do will always be temporary I’m afraid. Not been installed correctly from day 1. Hate to think what riser kit was used under that tray.
Do not underestimate the dynamic forces on a shower tray. Average person weighs say 10 stone concentrated on two feet, its a lot of pressure moving around. Shower trays especially flimsy ones are notorious for twisting. More than adequate support is essential. Then when there is a leak even a small one then walls swell, timber rots...a nasty brew. Take the tray out, clean out base under, treat for wood rot if necessary. Scrape all the old sealant away. Then rebuild base raising the shower tray up and under the lip with a reasonable bead of quality sillicon. However the real fix is to start again bottom up with a re tile. centralheatking
How much (ball park figure) as best you can do you think I would be looking at for some to fix it? Also approx how long would it take? I'm assuming I would also need to try and find some matching tiles somewhere.
Stew, firstly establish if tray is not on the move when someone is standing in it, if it doesn't move I would suggest you take the whole bottom row of tiles off depending if you have replacements, replace the boarding now exposed hopefully its not plasterboard but bet you it is. Use a hardy backer type board or similar of a same thickness and bring to the top of the tray or slide down the back depending how it currently is. Seal the board to the tray. Now using your new tiles cut to size allowing no more than a a 2-3mm gap where it meets the tray. its a days work depending on whether the screen has to come out, so a days money. Cost depends where you are so can't give a figure £300-400 at a guess
