View the thread, titled "lead lock fitting" which is posted in UK Plumbers Forums on UK Plumbers Forums.
hi guys
could anyone please tell me what order these things go onto lead pipe
1 locking nut
cheers
Haven’t used that type before you you’ve got it in the right order I would say
t shape olive into the compression nut so the upstand is into the nut eg right of the olive
thanks shaun for your reply
going onto lead pipe in this order?
1 locking nut
2 rubber o ring
3 t shaped olive flat end next to o ring
4 fitting
the question is does oring go to 15mm fitting end or lead end after locking nut
It could be either A or B.
It depends on the shape of the inside of the fittings.
Does the locking nut have a square base or a tapered base.
The same with the internals of the fitting the locking nut screws to.
I'm leaning towards B.
There's no way that O ring would put up with the force of squashing the olive around the pipe as in Pic A
Reply to the thread, titled "lead lock fitting" which is posted in UK Plumbers Forums on Plumbers Forums.
