Guest viewing is limited
Leak has developed from cistern inlet pipe valve\flexi-hose
View the thread, titled "Leak has developed from cistern inlet pipe valve\flexi-hose" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Phil999
Appreciate any help with this please.
All of a sudden my toilet has started to leak from inlet valve
pipe thread where it goes into the bottom of the cistern bowl.
I tried to seal it with fornex lsx by putting it on the thread which
has stopped it but now the leak has moved to the flexi-hose
and is coming out of the metal collar where it meets the nut of the flex-hose connector that screws onto the inlet valve pipe.
Any ideas how to stop this please.
Thanks for any help as I am a novice at plumbing.
To trace the exact point where the leak starts use dry tissue paper under the cistern where the first plastic nut is. If it`s leaking here then it`s the washer Inside the cistern which has most likely rotted.
PS Water runs downhill!
What RPM is right it could also be the ferrule of the flex or the rubber washer has failed or the thread and nut has crossed threaded or the inlet valve has a failure (split but invisible).
As RPM says, check with tissue on the back nut of the fill valve (and tighten if necessary) or replace the flex hose, and then the fill valve and if you can, get a brass shank (fluidmaster pro) inlet valve.
Hope this helps
BTW I have had all the failures happen at some time
Russell
Reply to the thread, titled "Leak has developed from cistern inlet pipe valve\flexi-hose" which is posted in UK Plumbers Forums on Plumbers Forums.
Phil999,
iiplumbing,
