View the thread, titled "Leaking Automatic air valve to Bolier" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
J
Jim Cooper
Can someone advise a newbie please?
Sorry all trying to get the hang of these postings.
My question was to be, ' I have a Baxi 100 HE condensing boiler, on an Indirect system which has a leaking AAV. I have recently de-sludged the system ( all radiators); and I am flushing out with new water fill before refillilng & including a Inhibitor.
I have been advised to remove the AAV and clean out to remove any dirt that may be blocking the flat vave.
Do I need to empty the Hot water system as well as the primary radiator waters to remove the AAV?
Your responses would be appreciated
if the aav is on the boiler which i assume is a system boiler you just need to turn of the iso valves under the boiler
id just change it once they leak
Thanks Steve, The System is open vented. If you could explain "iso valves under the boiler " as I cannot see any.
I presume you mean by "just change it once they leak" is to replace the complete AAV?
R
Jim
R
Jim
sorry wrong boiler if theres no valves you'll have to drain the heating and yes best to replace leaking aavs especialy as you need to drain to chage
Reply to the thread, titled "Leaking Automatic air valve to Bolier" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
Jim Cooper,
Jim Cooper,
