E
eric bushby
Hi all, I am new here.
I am not a plumber but a retired long time electrician working in industry. Most of my work was on water cooled, high power, high voltage components and circuitry so pipework and fittings always came into it.
Boiler type Glow.worm Flexicon 24 hx
I have turned the power and the gas off.
I have a leak on my boiler where the supply hot water exits the top of the stainless steel boiler. It leaks where the 22mm copper tube fits into the cast iron elbow and so far I cannot get that joint apart. I have removed the fixing screws to the top of the boiler and have now removed the double pronged steel clip from the elbow.
The elbow is still solid to the copper tube and I have not come across this type of fitting before.
How do I get the elbow off the tube to see how to fix it.
Hoping you can hep
Regards
Eric
Hoping you can hep
Regards
Eric
