Leaking Boiler
View the thread, titled "Leaking Boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
G
Gas Lady Mids
Hi.. I had a call for a break down of a combi boiler. When I arrived at the property there was no power to the boiler at all.. Customer stated that he tested the fuse in the spur and it is working. Anyway customer informs me that when the boiler went out it kept trying to relight, making several noises then blew the main electrics entirely. Now the boiler is leaking. I took the boiler apart and noticed some discolouration on PCB. I think that has blown so I have ordered a new part, I have drained down the boiler but it is still leaking. from the diverter valve. I have isolated the water supply to the boiler but it is still leaking from the diverter. I have had to turn the mains water off.. Any ideas where this water is coming from guys and why it maybe leaking thru the diverter valve?!!!...
The boiler contains a lot of water.
You can isolate the boiler and drain it down but if you've ever changed a pump in the boiler or diverter valve, no matter how many times you think yoiu've drained it, there's always a bit more.
It's just perseverance.
It'll get there in the end
Sorry.. Forgot to say - when I turn the water off at the mains, there is no leak. When i turn it back on, the diverter continues to leak.
How is that possible if i have isolated the water at the boiler???:13:
The cold water supply at the boiler... ?? I thought that was right.. Sill new to the game.. Got my certificate last week
The isolation valve could be letting by.
If you're in a fix then it might be worth cutting a ball-o-fix into the incoming cold to the boiler. That way you'd be certain it was off
Ok.. Thanks.. Do you think that if water is leaking from the diverter it will need replacing?
No not a wind up.. I was advised today that the diverter could be repaired.. I was asking (In someone else's opinion) if it needs replacing.. meaning is it worth repairing!!!
Reply to the thread, titled "Leaking Boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
Gas Lady Mids,
Syty,
