C
CBR_TONY
Hi have a Worcester 240 combi which has got a pretty bad leak from the by-pass valve which I believe may also be causing the system to not maintain pressure?
I have attempted to adjust the valve by screwing it in and out but it still leaks! What is the cause of these valves to fail and does it mean it will have to be replaced to rectify the problem?
Tony
did you have a build up and increase in pressure befour the leak started once they start to open they con be stubborn to close again fully because dirt or crud can get inbetween the parts that make it wartertight so swapping the part might only be part of the soultion if the expansion vessel has failed or just lost pressure
I don't think they are going to reply considering they were only guests and the thread was 4 years ago 🙂
