Leaking nut on water feed for loo flush
View the thread, titled "Leaking nut on water feed for loo flush" which is posted in Bathroom Advice on UK Plumbers Forums.
C
Camille2000
Second attempt at first post...
About a year ago we had a new Bathstore bathroom fitted. Recently the pipe which feeds water from the cistern to the bowl has started to leak. I've tried myself to re-tighten it, but with little success. It's in a very hard to reach area round the back of the base of the loo. In my opinion the nut is leaking because the guy that fitted the bathroom has cross-threaded the nut.
I was wondering if there's a special spanner of some sort I need to do the job properly?
have you tryed striping it down cleaning the fittings and seeing if its cross threaded.
maybe a pic will help see what your saying try and take the fitting off and replace it or use a bead of silicone round the seal?? you dont want to be trying to fight in tight spaces every day use a but set of grips and a cloth over the nut so not to mess it up take your time just chill out
I've tried. No links or photos allowed for new members it seems.
Perhaps I can PM a pic to you?
Post denied. New posts are limited by number of URLs it may contain and checked if it doesn't contain forbidden words.
rrrr i see now lol if the plastice is cross threaded you need a new filler flexi looks like it needs a clean best thing to do is turn off the water at ISO then flush system drain out left over water with towles or mop then strip it down defo need new filler
Cheers for your help.
My main problem is undoing or tightening the nut, I just can't get to it and there's not enough room to do either with a spanner. I'm wondering if there's a special tool I need to do it properly?
tap spanner
I've tried using a tap spanner with the jaw bit that folds down, perhaps I need one of those other types.
Do they all come on one size and fit those nuts? Is it a basin wrench? I'm not sure of the size of the nut, that's the problem.
Do you have a link to the type you have in mind?
Small adjustable is no good. Not enough room to turn it. I'm thinking of a sort of half tube spanner with a bar I can twist.
That jaw dropper looks like it would work if it was shorter as there are pipes directly underneath..
it is plastic thread, so you need to be very careful, easy to overtighten and damage the threads.
you will need to have the fitting apart to see what is happening,
this might mean having to take the cistern away from the pan??
if its a fibre washer tightening it could just rip the washer.
so you will at least need to re washer (fibre/rubber?)
you might end up fitting new flush valve and new flexi tap connector, and close coupled kit???
To do that I still need to undo the flexi hose, so I'm off the Homebase in the morning to see what I can find to do the job.
If the cistern can be removed okay, then do so, - don't mess about trying to get at that back nut of the fill valve. It would have initally had the fill valve tightened in place before the cistern was fitted & that's the way to do it again. You could also tighten the flexi on first & let it drop through the hole in bowl, - that way it's easier to tighten & not cross thread it, although an open spanner would do it.
You undo the flexi hose easily with a spanner when the cistern is removed. Easy job, just undo the flexi at the joint to the pipework, undo the wing nuts under the cistern and lift off complete with flexi. There may be a couple of screws on the back of the cistern holding it to the wall. If there are, remove these too.
like above replace with a fluidmaster brass ball valve then you won't cross the threads..
that's ok then. turn the water off at the iso, flush the toilet which will mostly empty the cistern. mop the rest out with a sponge or similar, undo the bottom flexi nut with a towel round it as ther will be a small amount of water come out. you can then remove the cistern. you can get to the leaking part as you won't have the restriction of the pan or other pipes in the way.
Have you contacted the original installers? Won't they come back to sort the problem, if its cross threaded a decent tradesman will at least do a free repair or even pay for damage done......water mark on ceiling below?
If there cowboys like the op said before then don't think thy will come back but you never know!!!
What made you say there cowboys anyway?? its not allwase the tradesman thats the cowboy not starting a fight but mite of been down to the op giving them a hard time etc JUST SAYING
Reply to the thread, titled "Leaking nut on water feed for loo flush" which is posted in Bathroom Advice on Plumbers Forums.
Camille2000,
Dotty,
