R
RafeDonson
I've just rented a house and I've noticed one of the radiator valves was leaking as the pressure had dropped on the central heating to the point where it wouldn't work. So I put some plumbing - PFTP or whatever - tape on it, following a Youtube video.
This slowed down the leak, to the point where I only needed to refill it with the loop after a month. The video advised to add more tape if this happened, which I've done.
Thing is, is there any downside to this? Is adding too much tape going to be a problem? I'll mention the leak to the landlord when I next see him (I'll take out the tape and not mention I'd plugged it) - but is this a fix or am I just delaying the inevitable of the valve needing replacing?
