View the thread, titled "Leaking Shower Pipe" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
N
natstan
Hello forum members!
I'm was hoping you could help me please?!
My shower (valve mixer type) is leaking, well the hot water pipe which is behind a tiled wall. We identified the leak by pulling up the carpet and floor boards outside the bathroom on the opposite side of the wall where the shower is fixed and were able to see the water and
The guy that fitted the bathroom which is just over a year old has suggested accessing the shower pipes from the hallway dry wall (think that's what you caLL it) to me this seems the most logical way and would require less work as we could easily build the wall back up or create an access panel.
Can you please advise if you think this is the best solution and or if there's anything else we need to consider?!
Thanks in advance!
Nat
Hi Nat
I agree with your plumber its best to access from the hallway dry wall.
it will be cheaper to access the pipes from here as you won't have to hack off the tiles and you should be able to locate the leak from here
Take his advice. How long has it been leaking
Thanks for your response - I'm not sure actually we spotted it because of water stains on the kitchen below which aren't huge. I just hope it's not a leaking shower valve, if it is, would that be a bigger problem?
Nat
Thanks for you help all!
Any advice if it turns out to be a leaky valve? I only bought the shower just over a year ago and believe its under warranty for 5 years fortunately..
Is the shower built into the wall or is it surface mounted as ive seen the surface ones not being properly sealed as they come through the wall , if built in then the only problem with coming from hallway side is if the plumbers put wood on to fix the shower then it can be awkward depending on the size of the wood,
Hi Kris
what do you use to seal the pipe holes coming through the wall?
Hi Kris
The valve is mounted onto the tiled walls and the pipes are behind the wall - sorry I'm not very clued up on these things so based on what I've told you im not sure what it is?!
Also what do you mean by 'plumbers put wood on to fix the shower'?
Also to be sensible, after the leak has been looked at and fixed, should we wait a while before sealing the dry wall back up just to ensure its not still leaking? Once we're satisified its fixed we can seal the wall back up?
Thanks again!
Nat
Thanks again!
Nat
No need in my opinion. Once the leak has been fixed, it's pretty much done and you can go about sorting the wall out. Otherwise you'll be tempted to wait, and then wait a little more just to make sure. And then maybe wait a little more. You get the idea. Trust your plumber :teeth_smile:
Reply to the thread, titled "Leaking Shower Pipe" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
