View the thread, titled "Leaking Shower Valve" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
I have a leak coming from the bath/shower/off switch on the attached shower valve.
The leak is coming from what looks like a rubber washer behind a brass retaining clip.
I've not removed the retaining clip as if I make the leak worse I won't be able to switch the water back on.
Any ideas with this one? Is it likely simply a new rubber washer, new cartridge?
Apologies, I don't know the model of the shower, although it is about 15 years old.
That is the flow cartridge. It is likely to be a ceramic disc mechanism, could be grit caught between the discs so it never shuts off properly- this is then leaking up the gland.
I would remove the cartridge, photograph measure and look for identifying numbers.
Then reassemble greasing up or replacing any o-rings in the spindle. Then try to find a replacement cartridge using what you found in removal.
Reply to the thread, titled "Leaking Shower Valve" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
Thread starter
Joined
Location
Manchester
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
Thread Tags
MrGatch,
Ben-gee,
